When you execute CLI commands or retrieve live data in a runbook, read the following reference for explanations about data retrieval status.
Retrieval Result for Individual Command or Data Type
The following table describes the explanation of retrieval results for individual command and data type.
Icon
Explanation
Command or data type has been successfully retrieved from the selected device.
Command or data type cannot be retrieved from the selected device.
Command or data type is not applicable to the selected device.
Note: This result is only available in Retrieving Live Data.
Retrieval Result for Device
Data retrieval status for a device may differ depending on different combinations of retrieval results for commands and data types.
The following table describes the explanation of retrieval results for devices and related combinations.
Icon
Explanation
Combinations for Individual Results
No failure records of data retrieval on this device.
No success records of data retrieval on this device.
The selected device has both success and failure records.
All commands or data types are not applicable to this device.
Executing CLI Commands
