Dynamic data views can only be deleted in the Data View Template Manager.
1.Click the start menu
to select Data View Template Manager.
2.In the Data View Template Manager pane, point to the target data view and click the
icon to select Delete.
To delete static data views under the Scheduler folder, see Deleting a Static Data View for more details.
1.In the Data View pane, click Static Data View.
2.Point to the target data view generated by saving as, then click the
▪Delete for All Devices — delete the data view from the system.
▪Delete for this Map Only — delete the data view for matched devices on this map only, and keep for others. As a result, this data view still can be browsed in the Data View Manager for the rest of devices.
Map data views can be deleted not only from a map, but also in the Map Data View Manager.
Tip: To delete the target data views in Map Data View Manager, see Deleting a Map Data View for more details.
1.On a map, click the
icon behind the applied data view name at the upper-right corner of the map
2.Click the target map data view to apply it to the map page.
3.Click the
