Using NetworkBrain Smart CLI
NetworkBrain Smart CLI is an SSH and Telnet client for the Windows platform. You can use it as a standalone tool to execute CLI commands or integrate it with NetworkBrain IE to automatically log in to devices, execute CLI commands and send CLI results to your NetworkBrain IE for documentation and troubleshooting.
Note: Before using NetworkBrain Smart CLI, you need to install Smart CLI on Windows first.
User Flow
The following is a recommended flow for using Smart CLI along with NetworkBrain IE:
1.Connect to Devices from NetworkBrain Map.
2.Execute CLI Commands in Smart CLI Window.
3.Save CLI Results to NetworkBrain Runbook.
4.Compare CLI Results with Historical Data to View Changes.
