Configuring Live Access Advanced Settings
In the Advanced Settings, you can configure the following information related to live access:
Network Security (such as hide sensitive data in configuration)
Network Credentials Settings for Change Management Module
Live Access Timeout Settings
SNMP Hostname Trimming
Management Interface Selection Order
Maximum Routing Table Entries
Live Access Polling Order
LAN Mask Settings for L2 Topology Building
Proceed with the following steps to configure the advanced settings:
2.In the Domain Management page, click Operations > Domain Settings > Advanced Settings from the quick access toolbar.
3.On the Advanced Settings tab, configure the following live access settings based on your needs and click Submit.
Network Security
Build L2 Topology Option
Select Access Credential for SSH/Telnet CLI and Change Management
Timeout
SNMP Hostname
Polling Order
Max route table entries
