With NetBrain, you can quickly visualize and understand a Cisco ACI fabric from the following aspects:
▪What you have in your Cisco ACI Fabric, such as physical devices and their topology.
▪The detail information of a node, such as properties, chassis, interfaces, and fabric extenders.
▪The overlay design over a Cisco ACI Fabric, such as logic layer dependency, and connectivity inside or outside an application.
▪More data information by applying data views.
Follow the steps below to visualize your ACI network:
1.Discover ACI data in your NetBrain Domain
3.Understand the Network Structure of an ACI Fabric
4.Understand the Application Deployment Over an ACI Fabric
5.Calculate A-B Paths Across ACI Fabric
6.Apply Data View to Visualize More Fabric Data
