1.Click the
icon at the upper-right corner of the Qapp Editor.
2.Re-name the Qapp, such as Monitor Interface Parameters.
3.Save the Qapp to the target location. See Qapp Center for details on the target locations.
1.Map the target devices.
2.On the map page, right-click on the blank area and select Run Qapp from the drop-down menu.
3.Select the Qapp you have created, and click OK.
4.Click Run in the opened Runbook pane.
Tip: You can configure more settings such as data source, frequency and threshold before running a Qapp. See running a Qapp for more details.
