Qapp Center is a self-contained manager that provides you with a comprehensive view of all accessible Qapp files.
Working with Qapp Center
1.Click the start menu and select Qapp Center. The Qapp Center pane contains the following three categories by default:
Built-in Qapps contains the pre-installed Qapps. This category is accessible to all users but can only be modified by system administrators.
Shared Qapps in Tenant — contains Qapp files that are accessible to all users in this tenant.
My Qapps — contains Qapp files that are only accessible to yourself. You can find your private Qapps in all accessible domains under one tenant.
2.Point to a Qapp file and click the icon to preview it.
Further operations:
Creating a Folder in Qapp Center
Importing Qapps into Qapp Center
Exporting Qapps from Qapp Center
Saving a Qapp to Another Destination
Running a Qapp
Parser Library
Writing Your First Qapp
