Use this API to run a scheduled discovery task right away.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Discovery/Tasks/{task}/Run |
Yes |
Name |
Token*required |
task*required |
Input the name or ID of the scheduled discovery task added on benchmark page. Get a task ID by using the API Get all discovery tasks in a domain. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
