Use this API call to get an authentication token and start a session.
Method |
URL |
Required authentication |
POST |
base_url/V1/Session |
No |
Tip: The base URL is http(s)://<IP address of your NetBrain Web API Server>/ServicesAPI/API.
Name |
Example |
body *required |
The body contains two parameters: ▪username*(string): the username to log into your NetBrain domain. ▪password*(string): the password to log into your NetBrain domain. ▪authentication_id (string): the authentication ID of an external user through SSO, LDAP/AD or TACACS. This parameter is only required for an external user and the value is alias. |
Note: The content type that NetBrain APIs support is application/json.
Parameter |
Type |
Example |
token |
string |
The returned authentication token. |
statusCode |
integer |
statusDescription |
string |
After receiving a token, associate your session with a tenant ID and domain ID. To find your tenant and domain ID, call APIs to get a list of tenants and domains that can be used.
