Use this API to get all discovery tasks in the current domain.
Tip: If there are no discovery tasks in the system, add a new discovery task from the Domain Management page. In the discovery task, select Once on the Frequency tab and Discover the following IPs on the Discovery Seed tab.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Discovery/Tasks |
Yes |
Name |
Token*required |
Parameter |
Type |
Example |
tasks |
list |
A list of all discovery tasks. |
id |
string |
The ID of a discovery task. |
name |
string |
The name of a discovery task. |
enable |
bool |
Whether a discovery task is enabled. |
lastStatus |
string |
The last run (result) status of a discovery task. |
lastRunSpan |
integer |
The duration of the last run of a discovery task. |
curStatus |
string |
The current status of a discovery task. |
nextRunTime |
string |
The start time of the next run of a discovery task. |
frequency |
string |
The run frequency of a discovery task. |
statusCode |
integer |
statusDescription |
string |
