Note: Service Monitor is a portal for administrators to observe the health of deployed NetBrain servers (including both Windows servers and Linux servers), with operations management of related services. It is highly recommended to install it on your NetBrain servers that require monitoring.See Monitoring Server and Service Metrics for more details.
1.Obtain the netbrain-servicemonitoragent-windows-x86_64-7.1a2.zip file from NetBrain and save it in your local folder.
2.Extract installation files from the netbrain-servicemonitoragent-windows-x86_64-7.1a2.zip file.
3.Right-click the netbrain-servicemonitoragent-windows-x86_64-7.1a2.exe file, and then select Run as administrator to start the Installation Wizard.
2)On the System Configuration page, review the system configuration summary and click Next.
3)On the License Agreement page, read the license agreements, and then click I AGREE.
4)On the Destination Location page, click Next to install the Service Monitor Agent under the default path C:\Program Files\NetBrain\. If you want to install it under another location, click Change.
5)On the Web API Service Connection page, enter the following information to connect to your NetBrain Web API Server, and then click Next.
▪API URL — the URL used to call the Web API service, http://<IP address of NetBrain Web API Server>/ServicesAPI. For example, http://10.10.3.141/ServicesAPI.
Note: If SSL is enabled with https binding created for the system website in IIS Manager, use https in the URL. Besides, if you want to authenticate the Certificate Authority of the SSL certificate used by the system website (to be completed in the next step), the hostname must be specified in the URL.
▪API Key — the key used to authenticate the connections to Web API Server. By default, it is netbrain.
Note: The API Key must be kept consistent with the API Key configured in the web.config file located under the <IE_Install_Home>\Web Server\nb_publish_server directory on NetBrain Web API Server. <IE_Install_Home> is the root installation directory of the Web API Server. Here is the related entry in the web.config file.
<add key="ServiceMonitor.ApiKey" value="netbrain"/>
6)This step is required only if https is used in API URL. Configure whether to authenticate the Certificate Authority (CA) of the certificates used to enable SSL for NetBrain website in IIS Manager, and then click Next.
To authenticate CA:
a)Select the Conduct Certificate Authority verification check box.
b)Click Browse to upload the root or class 2 CA file used for CA authentication. For example, ca.pem.
Note: Only the certificate in Base-64 encoded X.509 PEM format is supported.
7)Review the summary of the installation information and click Install.
4.After NetBrain Service Monitor Agent is successfully installed, click Finish to complete the installation process and exit the Installation Wizard.
Tip: After the installation is completed, you can open the Task Manager and navigate to the Services panel to check whether NetBrainAgent is running.
Tip: The installation log file is saved under the C:\ drive. If you encounter any issues during the installation, check the log file for more details.
5.If you changed the default port number when installing a NetBrain server, you must add the customized port number to its corresponding configuration file so that the Server Monitor can detect and monitor its service. See Configuration Files for Port Information for more details.
The Service Monitor Agent checks the following configuration files for the customized port or service name information of NetBrain servers installed on Windows.
Server Name |
File Name |
Front Server |
fs.yaml |
Front Server Controller |
fsc.yaml |
Web API Server |
iis.yaml |
Message Server |
rabbitmq.yaml |
Cache Server |
redis.yaml |
Task Engine |
taskengine.yaml |
Worker Server |
workerserver.yaml |
Stunnel (SSL service agent for Redis) |
stunnel.yaml |
Example: If you configured a port number 6370 during Cache Server installation, add it into the redis.yaml file as follows.
1.Navigate to the C:\ProgramData\Netbrain\nbagent\checks directory.
Tip: The ProgramData folder is hidden usually. You can copy and paste the directory to navigate to the checks folder directly.
2.Open the redis.yaml file with a text editor to modify it.
Note: Follow the text format in the example strictly, including alignment, punctuations, and spaces.
init_config:
instances:
- name: default
port: 6370
