1.Prepare a Linux server. See System Requirements for more details.
2.Log in to the Linux server as the root user.
Note: If a MongoDB replica set has been deployed, you must install the License Agent Server on both primary and secondary nodes.
3.Obtain the netbrain-license-linux-x86_64-rhel7-7.1a2.tar.gz file from NetBrain, and then copy it to the /opt/netbraintemp directory.
▪Option 1: If the Linux server has no access to the Internet, upload the netbrain-license-linux-x86_64-rhel7-7.1a2.tar.gz file to the /opt/netbraintemp directory by using a file transfer tool.
▪Option 2: If the Linux server has access to the Internet and the yum command has been installed:
1)Run the yum -y install wget command to install the wget command if it has not been installed.
2)Run the cd /opt/netbraintemp command to navigate to the /opt/netbraintemp directory.
3)Run the wget <NetBrain IE 7.1a NetBrain License download link> command under the /opt/netbraintemp directory to directly download the netbrain-license-linux-x86_64-rhel7-7.1a2.tar.gz file to this directory.
Tip: Contact NetBrain Support Team to get the download link address.
Note: The download link is case-sensitive.
5.Run the tar -zxvf netbrain-license-linux-x86_64-rhel7-7.1a2.tar.gz command under the /opt/netbraintemp directory to extract installation files.
[root@localhost netbraintemp]# tar -zxvf netbrain-license-linux-x86_64-rhel7-7.1a2.tar.gz
License/
License/bin_7.1a1/
License/bin_7.1a1/libboost_chrono.so
License/bin_7.1a1/libboost_chrono.so.1.62.0
License/bin_7.1a1/libboost_date_time.so
License/bin_7.1a1/libboost_date_time.so.1.62.0
License/bin_7.1a1/libboost_regex.so
License/bin_7.1a1/libboost_regex.so.1.62.0
License/bin_7.1a1/libboost_system.so
License/bin_7.1a1/libboost_system.so.1.62.0
License/bin_7.1a1/libboost_thread.so
License/bin_7.1a1/libboost_thread.so.1.62.0
License/bin_7.1a1/libcrypto.so
License/bin_7.1a1/libcrypto.so.1.0.0
License/bin_7.1a1/libssl.so
License/bin_7.1a1/libssl.so.1.0.0
License/bin_7.1a1/licensed
License/fix_releaseinfo.json
License/install.sh
License/install_licenseagent.conf
License/netbrainlicense-7-1.noarch.rpm
License/upgrade.sh
6.Run the cd License command to navigate to the License directory.
7.Modify the parameters in the install_licenseagent.conf file located under the License directory according to your environment and save the changes. For how to modify the configuration file, see Appendix: Editing a File with VI Editor for more details.
[agent]
# The IP address of the License Agent Server.
bindIp=0.0.0.0
# The port number that the License Agent Server listens to. It should be more than 1024 and less than 65535. By default, it is 27654.
port=27654
# Specify whether to use SSL to encrypt the connections to the License Agent Server.
# By default, it is disabled. 0 indicates disabled, 1 indicates enabled.
UseSSL=0
# If SSl is enabled, you must enter the full path of the server certificate and key file.
Certificate=/etc/ssl/license_agent.crt
PrivateKey=/etc/ssl/license_agent.key
# Binary file location
#binRootPath=/usr
[log]
#Log path, file name is licensed.log
path=/var/log/netbrainlicense
#Log level, options: trace/TRACE, info/INFO, debug/DEBUG, warning/WARNING, error/ERROR, fatal/FATAL
level=INFO
#Log file size limit in bytes before rolling out, 100 or maxLogFileSize whichever is greater.
#After reach size limit, file will be rotated, backup file name would be with timestamp (in UTC) as suffix.
# licensed.log.<year>-<month>-<mday>T<hour>-<min>-<sec>, e.g. licensed.log.2018-01-17T19-49-43
maxLogFileSize=2000000
8.Run the ./install.sh script under the License directory to install the License Agent Server.
[root@localhost License]# ./install.sh
Preparing... ################################# [100%]
Bind IP: 0.0.0.0
License Agent port: 27654
The NetBrain License Agent will not use SSL to communicate.
Updating / installing...
1:netbrainlicense-7-1 ################################# [100%]
Bind IP: 0.0.0.0
Service name: netbrainlicense
User name: netbrain
User group: netbrain
NetBrain License Agent Server has been started.
NetBrain License Agent uses port 27654.
Redirecting to /bin/systemctl status firewalld.service
Successfully install NetBrain License Agent.
Finished to execute install.sh
9.Run the service netbrainlicense status command to verify whether its service starts successfully.
[root@localhost License]# service netbrainlicense status
netbrainlicense.service - SYSV: This shell script takes care of starting and stopping NetBrain license agent service.
Loaded: loaded (/etc/rc.d/init.d/netbrainlicense)
Active: active (running) since Tue 2018-11-27 01:38:01 EST; 57s ago
Docs: man:systemd-sysv-generator(8)
Process: 19452 ExecStop=/etc/rc.d/init.d/netbrainlicense stop (code=exited, status=0/SUCCESS)
Process: 19459 ExecStart=/etc/rc.d/init.d/netbrainlicense start (code=exited, status=0/SUCCESS)
Memory: 3.0M
CGroup: /system.slice/netbrainlicense.service
19463 /usr/bin/netbrainlicense/licensed -f /usr/licensed/licensed.conf
Refer to the following table for the parameters of License Agent.
Parameter |
Default Value |
bindIp |
0.0.0.0 |
Enter the IP address of the network card you want to use for the License Agent Server. Note: Modify the value only if you have multiple network cards on this machine. |
port |
27654 |
The port number that the License Agent Server listens to. |
UseSSL |
0 |
Set whether to encrypt the connections to the License Agent Server with SSL. To enable SSL, replace 0 with 1. For detailed requirements of SSL certificates and keys, see Appendix. |
Certificate |
/etc/ssl/license_agent.crt |
The storage path and name of the SSL certificate that contains the public key. Note: It is required only if UseSSL is enabled. Note: Don't set the values of the Certificate, PrivateKey, and path arguments to any personal directories, such as /root. Besides, don't include any special characters or spaces except slashes (/) in the values. |
PrivateKey |
/etc/ssl/license_agent.key |
The storage path and name of the SSL private key file. Note: It is required only if UseSSL is enabled. |
path |
/var/log/netbrainlicense |
The storage path for all License Agent Server log files. |
Level |
INFO |
The level of License Agent Server logs. Other available options: trace/TRACE, debug/DEBUG, warning/WARNING, error/ERROR, and fatal/FATAL. |
maxLogFileSize |
2000000 |
The maximum size of the log file in bytes. |
