The requirements of SSL certificates may vary for different NetBrain servers, depending on their different roles in SSL encrypted connections, SSL-server or SSL-client.
▪SSL Certificate Requirements for SSL-Server
▪SSL Certificate Requirements for SSL-Client
The following table lists the requirements of SSL certificates for NetBrain servers that work as SSL-server in encrypted connections.
NetBrain Server |
Required SSL Certificate and Key |
Format |
MongoDB Server Index Server License Agent Server Cache Server Message Server Front Server Controller |
▪Certificate that contains a public key. For example, cert.pem. ▪CA certificate (only required for Index Server). For example, ca.pem. |
Base-64 encoded X.509 PEM |
▪Private key. For example, key.pem. |
PKCS#8 key |
Tip: The certificates in PEM format usually have extensions such as .pem, .crt, .cer, and .key.
Note: By default, NetBrain servers that work as SSL-client don't require any SSL certificates. If you want to authenticate the Certificate Authority of the certificates for SSL-server, then the SSL certificates are required on SSL-client.
The following table lists the certificate requirements for SSL-client, including Web Server, Web API Server, Worker Server, Front Server, Front Server Controller, Task Engine, Service Monitor Agent, and Update Server.
Authentication Method |
Requirements |
Format |
Use the certificates installed on Windows |
▪All the certificates are valid and installed in the certificate store. ▪The certificate store must be under the Trusted Root Certification Authorities directory instead of the Personal directory. |
N/A |
Upload certificates when installing NetBrain servers |
▪For Front Server and Worker Server: CA certificate containing root CA certificate and class 2 CA certificate is required. ▪For other SSL-client: class 2 or class 3 CA certificate is required. |
