Use this API to get the status of a scheduled discovery task.
Note: If too many devices are scheduled to run in one task (for example, up to 50,000 network devices), this API may return a large amount of data and cause a performance issue.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Discovery/Tasks/{task}/Status |
Yes |
Name |
Token*required |
task*required |
Input the name or ID of the scheduled discovery task added on benchmark page. Get a task ID by using the API Get all discovery tasks in a domain. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
taskStatus |
integer |
The status of the task. The status has the following values: ▪-1: Unknown ▪0: Never run ▪2: Running ▪10: Succeeded ▪11: Succeeded with warnings ▪20: Failed ▪30: Manually stopped ▪31: Automatically stopped due to timeout set by users or another system setting. |
