Use this API to get the live logs of discovered devices.
Method |
URL |
Required authentication |
GET |
/V1/CMDB/Discovery/Tasks/{task}/LiveAccessLog |
Yes |
Name |
Token*required |
task*required |
Input the name or ID of a scheduled discovery task. Get a task ID by using the API Get all discovery tasks in a domain. |
IPs |
The list of IPs of discovered devices. Returns live logs of all devices if not specified. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
devices |
list |
A list of discovered devices. |
mgmtIP |
string |
The management IP of a device. |
livelogs |
string |
The live logs of a device. |
