Get the results of discovered devices
Use this API to get the results of discovered devices for a discovery task, such as whether succeeded to get the config of a device.
Resource Information
Method
URL
Required authentication
GET
/V1/CMDB/Discovery/Tasks/{task}/Results
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
task*required
(path)
Input the name or ID of the scheduled discovery task added on benchmark page. Get a task ID by using the API Get all discovery tasks in a domain.
IPs
(query)
The list of IPs of discovered devices. Returns results of all devices if not specified.
Response
Parameter
Type
Description
Example
Devices
list
A list of discovered devices.
  "statusCode"790200,
  "statusDescription""success",
  "devices": [
      "domainId""5e75247a-309c-4231-96a5-823b6cb1e78d",
      "source""Scan 172.24.101.12/32",
      "hostname""Bos-Core1",
      "frontServer""10.10.1.43",
      "ping""Succeeded",
      "SNMP""nb",
      "vendor""Cisco",
      "oid""1.3.6.1.4.1.9.1.324",
      "type""Cisco IOS Switch",
      "config""Succeeded",
      "telnetSSH""Succeeded"
domainId
string
The ID of the domain that a device belongs to.
source
string
The IP from which a device was discovered.
hostname
string
The hostname of a device.
frontServer
string
The Proxy Server used to discover a device.
ping
string
The ping to a device succeeded or failed.
SNMP
string
The SNMP community string of a device.
vendor
string
The vendor of a device.
oid
string
The OID of a device.
type
string
The type of a device.
config
string
Obtaining device configuration succeeded or failed.
telenetSSH
string
Accessing a device via SSH or Telnet succeeded or failed.
statusCode
integer
The returned status code of executing the API.
statusDescription
string
The explanation of the status code.
