Get all IPs added to a discovery task
Use this API to get all IPs added to a discovery task.
Resource Information
Method
URL
Required authentication
GET
/V1/CMDB/Discovery/Tasks/{task}/Seeds
Yes
Parameters
Name
Description
Token*required
(header)
Place the token received from the API Log in to get an authentication token.
task*required
(path)
Input the name or ID of the scheduled discovery task added on benchmark page. Get a task ID by using the API Get all discovery tasks in a domain.
Response
Parameter
Type
Description
Example
IPs
list
A list with all seed IPs.
  "IPs": [
    "192.168.0.1"
  "statusCode"790200,
  "statusDescription""success"
statusCode
integer
The returned status code of executing the API.
statusDescription
string
The explanation of the status code.
