1.On a map page, click Map > Map Settings on the map toolbar.
2.In the Auto Link between Devices area, select the default topology type for the auto link on your map.
Tip: You can select multiple topology types as default topology types in the auto link.
3.Click Set as Default. This change will be applied to all your new maps and new pages as default settings.
