2.From the quick access toolbar, select Operations > Domain Maintenance > Crawl Engine Manager.
3.In the Crawl Engine Manager, click + Add Parser into Crawl.
4.In the pop-up dialog, configure the following items.
Parser — click Select to select one or multiple parsers based on the data you want to collect and parse. See Parser for more details.
Target Devices — specify target devices for data collection, by site, device group, or individual device.
Note: The devices of which the device types are mismatched with the selected parsers will be automatically filtered out during data retrieval.
Frequency Category — select a frequency level for data retrieval execution: High, Medium, or Low.
Start Time & End Time — specify the time period for data collection and parsing.
Description — enter a message if necessary.
5.Click OK. The system generates a crawl task for each parser. All new crawl tasks are listed in the Crawl Engine Manager and enabled by default.
Running a Qapp
Searching for CLI Commands and Mapping Matched Results
