Creating a Qapp to Export Network Data to Local CSV File
This section will introduce how to use a Qapp to realize the function of CSV Report. With this function, you can easily export the retrieved device data to your local CSV file by using a Convert Operator.
Complete the following three steps:
1.Define Target Variables
2.Use Convert Operator to Convert Table
3.Export CSV File
