Defining Target Variables
1.Click the icon from the taskbar and select New Qapp from the drop-down menu to open the Qapp Editor.
2.Leave the Define Qapp Device Input field as it is and double-click the Canvas node.
3.In the Device Queue node, keep the default settings.
4.Extend a Device(this) node from the Device Queue node, and keep the default options.
5.Extend a CLI node from the this node. Enter the show version command in the Command field and select show version (Cisco Router, Cisco IOS Switch) from the drop-down menu. The related command, parser and variables will be auto-loaded.
6.Extend a Table node from the CLI node, click the icon, select the variable version and click Attribute>> to add it to the attribute table.
