Authentication and Initialization
To use NetBrain APIs, you need to authenticate user information to get access token. With the access token, you can specify a tenant/domain to get started with API calls.
In the Authentication category, the following APIs are included:
Log in to get an authentication token
Get all accessible tenants
Get all accessible domains of a tenant
Specify a domain to work on
Log out from a session
