Use this API to log out from the current session.
Method |
URL |
Required authentication |
DELETE |
/V1/Session |
Yes |
Name |
Example |
body *required |
The body contains one parameter: ▪token*(string): input the token received from login. |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
