Use this API to add a list of IP addresses as seeds to an existing scheduled discovery task.
Method |
URL |
Required authentication |
POST |
/V1/CMDB/Discovery/Tasks/{task}/Seeds |
Yes |
Name |
Token*required |
task*required |
Input the name or ID of the scheduled discovery task. Get a task ID by using the API Get all discovery tasks in a domain. |
Request*required |
The body contains the following parameters: ▪seeds* (list): a list of IP entries. The following is the information of each seed. omgmtIP* (string): the management IP address of a device. ocliType (integer): the access method to the device. When it is null, the SNMP method will be used. ➢0: Telnet ➢1: SSH ouserName (string): the username to access the device. opassword (string): the password to access the device. oprivilegeUsername (string): the username to enter the privileged mode of the device. oprivilegePassword (string): the password to enter the privileged mode of the device. odesignatedCredentials (bool): determine whether the API only uses the credentials you have specified. If false, the API will use credentials in network settings. osnmpCommunityString (string): the SNMP community string to access the device. ofrontServerOrGroupAlias(string): the alias of NetBrain Front Server to access your live network. Example: { |
Parameter |
Type |
Example |
statusCode |
integer |
statusDescription |
string |
