This section introduces the hardware requirements, network connectivity requirements, and more prerequisites for deploying a two-server system.
Reference Specification
Network Connectivity Requirements
Deployment Prerequisites
Note: The following specifications only apply to traditional network. Refer to Public Cloud System Specification if you have activated the public cloud (AWS/Azure) license.
The two-server deployment requires one Windows server for applications and one Linux server for the database. Both physical machines and virtual machines are supported.
Environment
NetBrain Component
Machine Count
CPU 1)
Memory
Hard Disk3)
Operating System
≤1000 nodes
≤10 users
Application Server
1
4 Physical Cores 1)
16GB
200GB
SSD
Windows Server 2012/2012 R2 (Standard/Datacenter Edition), 64-bit
Windows Server 2016/2019/2022 (Standard/Datacenter Edition), 64-bit
Database Server
1
4 Physical Cores 1)
16GB 2)
300GB
SSD
Red Hat Enterprise Linux Server 7.5/7.6/7.7/7.8/7.9/8.2/8.3/8.4/8.5/8.6, 64-bit
CentOS 7.5/7.6/7.7/7.8/7.9/8.2/8.3/8.4/8.5, 64-bit
Oracle Linux 7.7/7.8/7.9/8.2/8.3/8.4/8.5/8.6, 64-bit
Rocky Linux 8.4/8.5/8.6, 64-bit
Alma Linux 8.4/8.5/8.6, 64-bit
1001~2000 nodes
≤10 users
Application Server
1
4 Physical Cores 1)
32GB
200GB
SSD
Database Server
1
4 Physical Cores 1)
32GB 2)
300GB
SSD 4)
Alma Linux 8.4/8.58.6, 64-bit
Notes:
1) If hyper-threading is enabled, one physical core equals to two logical processors; in a virtual environment, the number of vCPUs required is twice the number of physical cores (as listed in the table).
2) Allocating at least half of the RAM amount for swap space on your Linux server is required to provide the necessary additional memory when the RAM space has been exhausted.
3) The required hard disk space must be exclusively reserved for NetBrain.
4) For better performance, it is recommended to install the MongoDB on a machine equipped with Solid State Drive (SSD), or Hard Disk Drive (HDD) RAID-10.
Source
Destination
Protocol *) and Port Number **)
Thin Client
Service Monitor Agent
Application Server
HTTP/HTTPS (80/443)
Application Server
Database Server
TCP 5672/6379/9200/27017/27654/15672 ***)
Application Server
Ansible Agent (add-on)
TCP 9098
Application Server
Live Network
ICMP/SNMP/Telnet/SSH/REST API
Database Server
Application Server
TCP 9099 ***)
Note: *) If SSL was enabled for any component including MongoDB/ElasticSearch/Redis/RabbitMQ/License Agent/Front Server Controller/Ansible Agent/Auto Update Server (within Web API Server), the SSL protocol should be added to firewall rules to enable SSL connection between servers.
Note: **) The port numbers listed in this column are defaults only. The actual port numbers used during installation might be different.
Note: ***) Ensure the newly added ports (9099 and 15672) are open for successful system upgrade to 10.0a.
The operating system must be installed with an English-language version (not language packs).
When installing NetBrain servers, comply with your company security policy to set the passwords and archive them for further reference.
NetBrain servers use hostnames to identify and communicate with each other. Make sure each server has a unique hostname.
Add all the NetBrain installation folders and files (on both Windows and Linux) to the allow list of antivirus software for routine scans, and keep the TCP connections unblocked between NetBrain components.
If the machine's firewall is turned on, make sure the firewall rules allow traffics to all the ports and protocols that will be used by the NetBrain system.
The Service Monitor Agent running on the Linux server(s) uses “netbrainadmin” user, and this user needs sudoers privilege to monitor other NetBrain components as well as to execute the system update tasks.
Special Requirements for Client Machine
Special Requirements for Windows Server
Special Requirements for Linux Server
Supported Web Browsers
Third-Party Dependencies
