NetBrain Smart CLI is an SSH and Telnet client for the Windows platform. You can use it integrated with NetBrain IE to execute CLI commands or integrate it with NetBrain IE to automatically log in to devices, execute CLI commands, compare execution results, and collaborate with others for troubleshooting.
Note: Before using NetBrain Smart CLI, you need to install Smart CLI on Windows first.
The following is a recommended flow for using Smart CLI along with NetBrain IE:
1.Connect to Devices from NetBrain Map.
2.Compare CLI Results with Historical Data to View Changes.
3.Share Findings to Collaborate with Others.
4.Automate Command Execution through Runbook.
