This section introduces the hardware requirements, network connectivity requirements, and more prerequisites for deploying a distributed system.
Reference Specification
Network Connectivity Requirements
Deployment Prerequisites
Note: The following specifications only apply to traditional network. Refer to Public Cloud System Specification if you have activated the public cloud (AWS/Azure) license.
As the number of network devices and concurrent users increase, the system requires a distributed environment, which requires more machines to provide resiliency and scale out flexibly based on your network scale. Both physical machines and virtual machines are supported.
Select an appropriate deployment way according to your node count:
Distributed deployment for 2001-5000 nodes
Distributed deployment for 5001-10000 nodes
Distributed deployment for 10001-50000 nodes
Distributed deployment for 2001~5000 nodes
Environment
NetBrain Component
Machine Count
CPU
Memory 2)
Hard Disk4)
Operating System
2001~5000 nodes
≤20 users
Web Server
Web API Server
Task Engine
Front Server Controller
Service Monitor
1
4 Physical Cores 1)
32GB
200GB
Windows Server 2012/2012 R2 (Standard/Datacenter Edition), 64-bit
Windows Server 2016/2019/2022 (Standard/Datacenter Edition), 64-bit
Worker Server
Service Monitor
1
8 Physical Cores 1)
32GB
200GB
Front Server
Service Monitor
1 4)
4 Physical Cores 1)
8GB
300GB (HDD)
(node # <=2000) 6)
300GB (SSD)
(node # <=5000) 6)
Red Hat Enterprise Linux Server 7.5/7.6/7.7/7.8/7.9/8.2/8.3/8.4/8.5/8.6, 64-bit
CentOS 7.5/7.6/7.7/7.8/7.9/8.2/8.3/8.4/8.5, 64-bit
Oracle Linux 7.7/7.8/7.9/8.2/8.3/8.4/8.5/8.6, 64-bit
Rocky Linux 8.4/8.5/8.6, 64-bit
Alma Linux 8.4/8.5/8.6, 64-bit
MongoDB
License Agent
Elasticsearch
Redis
RabbitMQ
Service Monitor
1
4 Physical Cores 1)
32GB
500GB (SSD) 4)
Distributed deployment for 5001~10000 nodes
Environment
NetBrain Component
Machine Count
CPU
Memory 2)
Hard Disk 4)
Operating System
5001~10000 nodes
≤50 users
Web Server
Web API Server
Task Engine
Service Monitor
1
8 Physical Cores 1)
32GB
200GB
Worker Server
Service Monitor
2
8 Physical Cores 1)
32GB
200GB
Front Server
Service Monitor
2
4 Physical Cores 1)
8GB
300GB (HDD)
(node # <=2000) 6)
300GB (SSD)
(node # <=5000) 6)
Red Hat Enterprise Linux Server 7.5/7.6/7.7/7.8/7.9/8.2/8.3/ 8.4/8.5/8.6, 64-bit
CentOS 7.5/7.6/7.7/7.8/7.9/8.2/8.3/ 8.4/8.5, 64-bit
MongoDB
License Agent
Elasticsearch
Redis
RabbitMQ
Service Monitor
1
8 Physical Cores 1)
64GB
1TB (SSD) 8)
Distributed deployment for 10001~50000 nodes
Environment
NetBrain Component
Machine Count
CPU
Memory 2)
Hard Disk4)
Operating System
10001~50000 nodes
≤200 users
Web Server
Web API Server
Task Engine
Service Monitor
1
8 Physical Cores 1)
32GB
200GB
Worker Server
Service Monitor
3
8 Physical Cores 1)
32GB
200GB
Front Server
Service Monitor
3~10
4 Physical Cores 1)
8GB
300GB (HDD)
(node # <=2000) 6)
300GB (SSD)
(node # <=5000) 6)
MongoDB
License Agent
Elasticsearch
Redis
RabbitMQ
Service Monitor
1
8 Physical Cores 1)
128GB
2TB (SSD) 8)
Notes:
1) If hyper-threading is enabled, one physical core equals to two logical processors; in a virtual environment, the number of vCPUs required is twice the number of physical cores (as listed in the table).
2) Allocating at least half of the RAM amount for swap space on your Linux server is required to provide the necessary additional memory when the RAM space has been exhausted.
3) Each Front Server is recommended to manage 5,000 network nodes at most.
4) The required hard disk space must be exclusively reserved for NetBrain.
5) Minimum bandwidth requirement between Front Server Controller and each Front Server: 10Mbps.
6) For good performance of data processing and caching, it is recommended to install the Front Server on a machine equipped with:
- Solid State Drive (SSD) when managing up to 5000 nodes
- Hard Disk Drive (HDD) when managing up to 2000 nodes
7) In order to achieve the best performance, it is recommended that the network delay between the Front Server Controller and the Front Server be within 30ms.
8) For better performance, it is recommended to install the MongoDB on a machine equipped with Solid State Drive (SSD), or Hard Disk Drive (HDD) RAID-10.
Source
Destination
Protocol *) and Port Number **)
Thin Client
Web Server
Web API Server
HTTP/HTTPS (80/443)
Service Monitor Agent
Web API Server
HTTP/HTTPS (80/443)
Web API Server
Worker Server
Task Engine
MongoDB
TCP 27017
Web API Server
Worker Server
Elasticsearch
TCP (HTTP/HTTPS) 9200
Web API Server
License Agent
TCP 27654
Web API Server
Worker Server
Redis
TCP 6379
Web API Server
Worker Server
Task Engine
RabbitMQ
TCP 5672
Worker Server
Task Engine
Front Server
TCP 9095
Front Server
Live Network
ICMP/SNMP/Telnet/SSH/REST API
Front Server
Ansible Agent (add-on)
TCP 9098
MongoDB
License Agent
Elasticsearch
Redis
RabbitMQ
Web Server
Worker Server
Task Engine
Front Server
Web API Server
TCP 9099 ***)
Web API Server
RabbitMQ
TCP 15672 ***)
Note: *) If SSL was enabled for any component including MongoDB/ElasticSearch/Redis/RabbitMQ/License Agent/Front Server Controller/Ansible Agent/Auto Update Server (within Web API Server), the SSL protocol should be added to firewall rules to enable SSL connection between servers.
Note: **) The port numbers listed in this column are defaults only. The actual port numbers used during installation might be different.
Note: ***) Ensure the newly added ports (9099 and 15672) are open for successful system upgrade to 10.0a.
The operating system must be installed with an English-language version (not language packs).
When installing NetBrain servers, comply with your company security policy to set the passwords and archive them for further reference.
NetBrain servers use hostnames to identify and communicate with each other. Make sure each server has a unique hostname.
Add all the NetBrain installation folders and files (on both Windows and Linux) to the allow list of antivirus software for routine scans, and keep the TCP connections unblocked between NetBrain components.
If the machine's firewall is turned on, make sure the firewall rules allow traffics to all the ports and protocols that will be used by the NetBrain system.
The Service Monitor Agent running on the Linux server(s) uses “netbrainadmin” user, and this user needs sudoers privilege to monitor other NetBrain components as well as to execute the system update tasks.
Special Requirements for Client Machine
Special Requirements for Windows Server
Special Requirements for Linux Server
Supported Web Browsers
Third-Party Dependencies
