1.In your web browser, navigate to http(s)://<IP address of NetBrain Web Server>/. For example, http://10.10.3.141/.
Note: If SSL is enabled in the IIS Manager, you need to use https. For example, https://10.10.3.141/.
2.In the End User Login page, click Sign up.
3.In the Create Account page, enter the required information, such as email address, first name, and last name.
Note: The username cannot be modified once it is created.
4.Click Submit. Your request will be submitted to the system administrator for approval. Afterward, you will receive a Welcome email in your registered email box.
5.Follow the instructions in the email to activate your user account.
▪Logging in to Domain Management Page
▪Approving Register Applications
