The system provides you with a series of security measures to protect your confidential data.
Note: The configured password policies only apply to all newly created user accounts or modified user accounts. User accounts that are imported from external user authentications do not comply with the settings.
To modify the password policy, do the following:
2.In the System Management page, select User Accounts > Password Policy.
3.On the Password Policy tab, configure the password policy based on your needs, and click Save.
