Data View Template Manager
Data View Template Manager is a centralized place to manage and maintain the following categorized data view templates, including creation, deletion, renaming, editing, import, and export.
Built-in Data View Templates — contains the pre-installed templates. This category is accessible to all users but can only be modified and deleted by NetBrain Engineers with authenticated credentials (username/password). To customize a built-in template, you can submit a ticket to NetBrain.
Shared Templates in Tenant — contains templates that are accessible to all users in this tenant.
My Templates — contains templates that are only accessible to yourself and can be manually saved as shared templates. You can find your private templates in all domains that you can access under one tenant.
By applying a data view template, you can easily generate a dynamic data view on a map.
Branch
Creating a Data View Template
