Operator |
Example |
Merge two string-type variables. |
$routing = $bgp_config + $ospf_config |
Equals specified string. |
$a==$b?1:0 |
Not equals specified string. |
$a!==$b?1:0 |
Operator |
Example |
Add two number-type variables. |
$error = $input_error + $output_error |
Subtract two number-type variables. |
$error = $input_error - $output_error |
Multiply two number-type variables. |
$a*$b |
Divide two number-type variables. |
$a/$b |
Judge whether the value of a number-type variable is greater than that of another one. |
$cpu > 90 |
Judge whether the value of a number-type variable is equal to or greater than that of another one. |
$a>=$b |
Judge whether the value of a number-type variable is less than that of another one. |
$a<$b |
Judge whether the value of a number-type variable is equal to or less than that of another one. |
$a<=$b |
Judge whether the values of two number-type variables equal. |
$a==$b |
Judge whether the values of two number-type variables don't equal. |
$a!=$b |
abs |
Absolute value of the number-type variables. |
abs(-10) |
Use the lower-case operator for logical operations in compound variable definitions.
Operator |
Example |
and |
bool and bool |
or |
bool or bool |
not |
not bool |
The follow global functions are currently supported by compound variable definition:
Function |
Example |
GetTableRowCount |
Get the table row count for a table |
BGP neighbor count defined by: $GetTableRowCount($BGP_Neighbor) |
GetLastValue |
Get the last value of the parser variables |
CRC error increase count defined by: $CRC_error - GetLastValue($CRC_error) |
GetLastRowCount |
Get the last table row count during last data retrieval |
Rout Table Change Count abs(GetTableRowCount($Route_table) – GetLastRowCount($Route_table) |
