Supporting variables contains a group of key metrics referenced or defined in a data view template definition, including:
▪Built-in variable (GDR property)
▪CLI/SNMP/API/Configuration Parser variable
Supporting variables can be used as or applied to:
▪Device/interface positions.
▪Device/interface notes.
▪Device/interface highlights.
▪Referenced as a variable to define the conditions for recommended automations.
▪Conditions to control the display of variables, device/interface notes, device/interface highlights, and device-level recommended automations.
Note: Supporting variables belong to the data view template level, and can be used in all branches of a data view template.
