One map can contain multiple map pages. When you save a map, all map pages will be saved in one map file.
Tip: On one map page, the links in different topology types are supported, such as IPv4 Layer 3 topology, and Layer 2 topology. You can use the extend neighbors or auto link function to draw neighbors or links on a map.
You can perform the following operations based on your needs to manage map pages.
1.Click the page title at the upper-left corner of the map (for example, Page 1). The thumbnails of all map pages are listed. 2.Click Add Page to create a new blank page named Page 2. 3.Draw devices on the new page. |
1.Click the map title (for example, Page 1) at the upper-left corner of the map. By default, the thumbnails of all map pages are displayed. 2.Point to the target map page and click the 3.Click Yes when a confirmation dialog box prompts. |
