Golden Baseline serves as the reference standard of “healthy” status for various types of data. It can be auto-calculated based on historical statistics or manually defined, and can be further used as a basis or foundation for network management analysis and comparison, for example, troubleshooting.
Note: Golden Baseline only applies to parser variables of traditional devices.
▪Manually Define Golden Baseline
▪Auto Calculate Golden Baseline
▪View Golden Baseline Analysis Result
▪Applying a Data View Template
