The collaboration session of an incident allows you to post messages for any findings, add relevant maps and devices, invite more colleagues to join the incident.
1.Open an incident from the Quick Access toolbar.
2.Collaborate with others through Collaboration Session.
Collaboration Session is the main location for you to share your perspective, add maps and devices related to troubleshooting, and invite others to join an incident.
Icon |
Used to input interactive information and adjust the format layout. |
Used to add devices, then you can click to view device data. |
Used to mention users in the system. |
Used to upload local files as attachments. |
Used to insert a URL for reference. |
Used to insert map links. |
Used to insert runbook results |
Note: See Inviting Others to Access an Incident for more details.
