Recommended automations are a group of tasks elaborately designed to analyze and troubleshoot a certain network issue, building a bridge to connect dynamic maps with network automation for diagnosis and troubleshooting.
The system provides two levels of recommended automations in DVT definition:
▪Template level — perform actions targeting all devices on a map. Recommended automations at the template level are displayed unconditionally.
▪Device level — perform actions targeting specific devices/interfaces only, and its display is controlled via conditions.
The following table shows whether action input and device scope can be customized at each level of recommended automations.
Recommended Automation Level |
Support Customized Action Input? |
Support Customized Device Scope? |
Template Level |
Device Level |
Tip: Action input for most recommended automations can be customized. See Syntax for Defining Action Input for more details.
Tip: To customize device scope for recommended automations at the device level, see Syntax for Defining Target Devices for more details.
The following table introduces the recommended automations that can be defined at the template level and device level.
Recommended Automation |
Template Level |
Available at Device Level |
Data View Template |
Qapp |
Gapp |
Overall Health Monitor |
Execute CLI commands |
View Device Data |
Ping |
Traceroute |
Calculate Path |
Compare |
SPOG URL |
URL |
Runbook Template |
Verify Application |
