Syntax for Defining Action Input
The action input for each recommended automation is script-based. When you define a recommended automation in a data view template, the system will generate a JSON script to visualize the default or pre-defined input of the action. To ensure actions can run precisely to meet your expectations, you can customize input parameters in the script, such as data source for data retrieval, thresholds for alerts, and so on.
The built-in syntax can be used to define inputs for the following actions:
Data View Template
Qapp
Gapp
Execute CLI Command
Compare Data
Verify Application
SPOG URL
View Device Data
Ping
Traceroute
Path
Exception: Action input syntax does not apply to URL and Runbook Template.
Data View Template
The "Data View Template" action is used to apply a data view template to a map. Once applied, the action will be documented in a runbook.
JSON Example:
    "data_source": {
        "type": 0,
        "frequency": {
            "interval": 2,
            "times": 10
    "input_variables": {
        "multicasting_group_address": "239.1.1",
        "vrf": "$vrf",
        "vlan": "40"
The following parameters can be used in the JSON string to define the input for a Data View Template.
Parameter
Type
Description
Option Values
data_source
Object
An object created by NetBrain to contain all settings related to the data source for this Data View Template.
N/A
type
Number
The source to retrieve data.
0 - pull data from the current baseline.
1 - pull data from a live network only once.
2 - pull data from a live network regularly.
By default, the value defined in this Data View Template is used.
frequency
Object
An object created by NetBrain to contain all frequency settings for this Data View Template.
Note: This object and its included parameters are only required when type is set to 2.
N/A
interval
Number
The interval to retrieve data. Unit: minutes.
An integer or a decimal (rounding to two decimal places), larger than 0 and less than or equal to 3600.
times
Number
The number of times for data retrieval.
"Null" or an integer between 1 and 1000.
Tip: "Null" means "unlimited".
input_variables
Object
Include parameters for input variables that are pre-defined in this Data View Template.
Note: This object is only available when input variables are pre-defined in this Data View Template.
N/A
Qapp/Overall Health Monitor
The "Qapp" or "Overall Health Monitor" action is used to run a Qapp on a map. The action node will be documented in a runbook.
JSON Example:
    "data_source": {
        "type": 0,
        "frequency": {
            "interval": 2,
            "times": 10
    "threshold": {
        "High CPU Utilization - Error(>=)": "80",
        "High Input Traffic Utilization - Warning(>=)": "60"
        "a": 2,
        "b": "b"
The following parameters can be used in the JSON string to define the input for a Qapp, including Overall Health Monitor Qapp.
Parameter
Type
Description
Option Values
data_source
Object
An object created by NetBrain, containing all settings related to the data source.
N/A
type
Number
By default, the value defined in this Qapp is used.
frequency
Object
An object created by NetBrain to contain all frequency settings for this Qapp.
N/A
interval
Number
times
Number
threshold
Object
Include parameters for thresholds that are pre-defined in this Qapp.
Note: This object is only available when thresholds are pre-defined in this Qapp.
N/A
input_variables
Object
Include parameters for input variables that are pre-defined in this Qapp.
Note: This object is only available when input variables are pre-defined in this Qapp.
N/A
Gapp
The "Gapp" action is used to run a Gapp on a map. The action node will be documented in a runbook.
JSON Example:
    "data_source": {
        "type": 1,
        "frequency": {
            "interval": 2,
            "times": 10
    "qapp_nodes": [
            "qapp_node_id": "7",
            "qapp_path": "xxxxxx",
            "threshold": {
                "a": 1,
                "b": "b"
The following parameters can be used in the JSON string to define the input for a Gapp.
Parameter
Type
Description
Option Values
data_source
Object
N/A
type
Number
By default, the value is 1.
frequency
Object
An object created by NetBrain to contain all frequency settings for this Gapp.
Note: This parameter is only required when type is set to 2.
N/A
interval
Number
By default, the value is 2.
times
Number
qapp_nodes
Array<Object>
An object created by NetBrain to contain the information about each Qapp referenced in this Gapp.
Note: This object is only required when a Qapp contains thresholds or input variables.
N/A
qapp_nodes_id
String
The unique Qapp ID in this Gapp.
Note: Keep the default value as it is.
qapp_path
String
The location of this Qapp file.
threshold
Object
An object created by NetBrain to contain all threshold settings for this Gapp.
Note: This object is only available when thresholds are pre-defined in this Gapp.
N/A
 input_variables
Object
An object created by NetBrain to contain all input settings for this Gapp.
Note: This object is only available when input variables are pre-defined in this Gapp.
N/A
Execute CLI Commands
The "Execute CLI Commands" action is used to issue CLI commands to devices on a map. The action node will be documented in a runbook.
JSON Example:
    "commands": [
        "show version",
        "show interface"
    "templates": [
        "Public/OSPF Command Template",
        "Private/QoS Command Template"
The following parameters can be used in the JSON string to define the input for executing CLI commands.
Parameter
Type
Description
commands
Array<String>
Commands to be executed.
templates
Array<String>
The location of referenced command templates.
Note: The referenced command templates must exist in the system.
Compare Data
The "Compare Data" action is used to compare various data between two data sets. The action node will be documented in a runbook.
JSON Example:
    "data_set1": 0,
    "data_set2": 1,
    "compare_data": [
        "Configuration File",
        "Route Table",
        "NCT Table/IPsec VPN Table",
        "NCT Table/IPsec VPN Table[Real-time]"
The following parameters can be used in the JSON string to define the input for comparing device data.
Parameter
Type
Description
Option Values
data_set1
Number
The data source for dataset1.
1 - pull data from a live network.
The default value is 0.
data_set2
Number
The data source for dataset2.
The default value is 1.
compare_data
Array<String>
Include the data types for comparison.
Null or empty array - represents all data.
Built-in data: Configuration File, Route Table, ARP Table, MAC Table, NDP Table, STP Table, BGP Advertised-Route Table.
NCT table: starting with "NCT Table/".
Note: All types of NCT tables available in the system can be auto-completed. However, whether a defined NCT table applies to an actual device depends on its driver definition.
Verify Application
The "Verify Application" action is used to verify applications and paths. The action node will be documented in a runbook.
JSON Example:
    "data_source": 1,
    "options": {
        "top_relevant_application": 3
        "top_path_of_application": 3
        "use_config_in_current_baseline": true,
        "l3_active_path": false,
        "use_cli_with_arguments": false
        "calculate_when_deny_by_acl": false,
        "calculate_when_deny_by_policy": false
        "path_fix_up": true
The following parameters can be used in the JSON string to define the input for verifying applications.
Parameter
Type
Description
Option Values
data_source
Number
Number
The count of the most relevant applications based on application weight.
An integer between 1 and 100.
The default value is 3.
Number
The count of the most relevant paths in each application based on path weight.
Bool
Determines whether to use the configuration file in the current baseline.
The default value is true.
l3_active_path
Bool
Determines whether to calculate L3 Active Path.
The default value is false.
Bool
Determines whether to use CLI commands with arguments.
Bool
Determines whether to continue calculating path with ACL deny.
Bool
Determines whether to continue calculating path with policy deny.
path_fix_up
Bool
Determines whether to enable Path fix-up rules.
SPOG URL
The "SPOG URL" action is used to generate an URL displayed on a data view position, to redirect to the third-party systems.
Note: This recommended automation is only available at the device level.
JSON Example:
    "customized_variables": {
        "@var1": "239.1.1",
        "@var2": "$vrf",
        "@var3": "40"
    "link_on_columns": [
        "mask"
        "ip1"
The following parameters can be used in the JSON string to define the input for SPOG URL.
Parameter
Type
Description
Option Values
Object
A placeholder in SPOG URL to feed different values for different data units.
Note: This object is only available when at least one customized variable is pre-defined in this SPOG URL.
N/A
link_on_columns
Array<String>
The name of a table column where the SPOG URL will be displayed.
N/A
View Device Data
The "View Device Data" action is used to launch the view of device data, including configurations and various data tables.
JSON Example for Configuration File:
    "filter": "BGP/All BGP Configuration"
The following parameter can be used in the JSON string to define the input for viewing configuration files.
Parameter
Type
Description
Option Values
filter
String
A configuration filter.
Non-empty string.
The default value is Full Configuration.
JSON Example for Route Table, ARP Table, BGP-Advertised Route Table, NCT Table:
    "sub_name": "$vrf_name"
The following parameter can be used in the JSON string to define the input for viewing data tables.
Note: Input syntax does not apply to MAC Table and NDP Table.
Parameter
Type
Description
Option Values
sub_name
String
The sub name of the table.
Any string (empty string is allowed).
NCT Table - its default value is empty ("").
Route Table/BGP-Advertised Route Table - its default value is global.
Ping
The "Ping" action is used to ping a destination device from a source device. This action will be documented in a runbook.
JSON Example:
    "source": {
        "type": 0,
        "device": "$this",
        "interface": "$mgmt_interface"
    "destination": {
        "device": "$this",
    "options": {
        "timeout": 2,
        "packet_size": 64,
        "packet_count": 5,
        "no_fragment": false
The following parameters can be used in the JSON string to define the input for Ping.
Parameter
Type
Description
Option Values
source.type
Number
The type of the source device.
0 - Front Server
1 - Device name/IP address/DNS name
source.device
String
The device/DNS name, or IP address of the source device when source.type is set to 1.
Note: If source.type is set to 0, the configured value of source.device will be ignored and Front Server will be auto-selected.
Either a non-empty string or "$this".
The default value is $this, which represents the current device.
source.interface
String
The interface name or IP address of the source device when source.type is set to 1.
Note: If source.type is set to 0, the configured value of source.interface will be ignored.
An interface name or an interface IP address. It also supports a combination of interface name and IP address (separated by space).
The default value is null, which represents auto-selected.
destination.device
String
The device/DNS name, or IP address of the destination device.
destination.interface
String
The interface name or IP address of the destination device.
The default value is null, which represents Management IP.
timeout
Number
The timeout threshold for no reply.
An integer between 0 and 3600.
The default value is 2 seconds.
packet_size
Number
The packet size for the echo.
An integer between 36 and 18024.
The default value is 64 bytes.
packet_count
Number
The packet count for the echo.
An integer between 1 and 1024.
The default value is 5.
no_fragment
Bool
Judge whether no fragment is required.
Traceroute
The "Traceroute" action is used to trace routes from a source device to a destination device. This action will be documented in a runbook.
JSON Example:
    "source": {
        "type": 0,
        "device": "$this",
    "destination": {
        "device": "$this",
    "options": {
        "timeout": 3,
        "max_hops": 30,
The following parameters can be used in the JSON string to define the input for Traceroute.
Parameter
Type
Description
Option Values
source.type
Number
0 - Front Server
source.device
String
source.interface
String
An interface name or interface IP address. It also supports a combination of interface name and IP address (separated by space).
destination.device
String
String
timeout
Number
An integer between 1 and 3600.
The default value is 3 seconds.
max_hops
Number
The maximum number of hops.
The default value is 30.
Calculate Path
The "Calculate Path" action is used to calculate a traffic path from a source device to a destination device. This action will be documented in a runbook.
JSON Example:
    "protocol": "IPv4",
    "source": {
        "device": "$this",
        "port": 2033
    "destination": {
        "device": "$this",
        "port": 2033
    "direction": 1,
    "data_source": 1,
    "options": {
        "path_fix_up": true
The following parameters can be used in the JSON string to define the input for path calculation.
Parameter
Type
Description
Option Values
protocol
String
The designated protocol for path calculation.
The default value is IPv4.
source.device
String
The device/DNS name, or IP address of source device.
A non-empty string or "$this".
source.port
Number
The port number of the source device.
Note: This parameter is only required when the designated protocol requires a port number.
An integer between 0 and 65535.
destination.device
String
destination.port
Number
The port number of the destination device.
direction
Number
The direction for path calculation.
1 - one-way path.
3 - two-way path.
data_source
Number
Bool
Judge whether to use the configuration file in the current baseline.
l3_active_path
Bool
Judge whether to calculate L3 Active Path.
Bool
Judge whether to use CLI commands with arguments.
Bool
Judge whether to continue calculating path with ACL deny.
Bool
Judge whether to continue calculating path with policy deny.
path_fix_up
Bool
Judge whether to enable Path fix-up rules.
