String Operators
Number Operators
Logical Operators
Global Functions
String Operators
Operator
Description
Example
Merge two string-type variables.
$routing = $bgp_config + $ospf_config
Equals specified string.
$a==$b?1:0
Not equals specified string.
$a!==$b?1:0
Number Operators
Operator
Description
Example
Add two number-type variables.
$error = $input_error + $output_error
Subtract two number-type variables.
$error = $input_error - $output_error
Multiply two number-type variables.
$a*$b
Divide two number-type variables.
$a/$b
Judge whether the value of a number-type variable is greater than that of another one.
$cpu > 90
Judge whether the value of a number-type variable is equal to or greater than that of another one.
$a>=$b
Judge whether the value of a number-type variable is less than that of another one.
$a<$b
Judge whether the value of a number-type variable is equal to or less than that of another one.
$a<=$b
Judge whether the values of two number-type variables equal.
$a==$b
Judge whether the values of two number-type variables don't equal.
$a!=$b
abs
Absolute value of the number-type variables.
abs(-10)
Logical Operators
Use the lower-case operator for logical operations in compound variable definitions.
Operator
Example
and
bool and bool
or
bool or bool
not
not bool
Global Functions
The follow global functions are currently supported by compound variable definition:
Function
Description
Example
GetTableRowCount
Get the table row count for a table
BGP neighbor count defined by:
$GetTableRowCount($BGP_Neighbor)
GetLastValue
Get the last value of the parser variables
CRC error increase count defined by:
$CRC_error - GetLastValue($CRC_error)
GetLastRowCount
Get the last table row count during last data retrieval
Rout Table Change Count
abs(GetTableRowCount($Route_table) – GetLastRowCount($Route_table)
Defining Flash Probe
