2.In the Domain Management page, click Operations > Topology Manager > Topology Link Manager from the quick access toolbar.
Property |
Topology Type |
See topology types for more details. |
Update Time |
The last time that the topology type was updated. |
Update Source |
The source that causes the update of the topology type, including ▪Manually rebuild ▪On-demand discovery ▪Scheduled discovery task ▪Server benchmark task |
Total Topology Link |
The total number of links in the topology type. |
Disabled Topology Link |
The total number of disabled topology links. |
3.Click the hyperlink in the Total Topology Link column of the target topology type. All the links in the selected topology type are listed on a new page. You can browse the following details of a topology link.
Property |
First Device |
The hostname of the first device and the corresponding interface name in the topology link. |
Second Device |
The hostname of the second device and the corresponding interface name in the topology link. The interface name is empty if the first device connects to a media. |
Media Type |
The type of the media that connects to the first device. See Media for more details. |
Created By |
The contributor that leads to the creation of the topology link, which includes the following types: ▪System ▪Qapp ▪Manually |
Source |
The specific source used to create the topology link. ▪If the topology link is created by System, this field displays the hyperlink of related source file used in topology calculation, such as Configuration File, NDP Table, ARP table. ▪If the topology link is created by running a Qapp, this field displays the Qapps used in topology calculation. ▪If the topology link is created manually, this field displays the username who creates the topology link. |
Update Time |
