All devices on a map page are displayed in the default data view. You can apply a static data view to decode network design.
1.Open a map page, click the Static tab in the Data View pane.
2.Click static dv8_Collect CPU Utilization to preview it.
3.Click Apply.
Tip: You can also directly double-click the target data view to apply it to the map page.
Tip: To clear applied data views, right-click the blank area on the map and select Data View > Clear All from the drop-down menu.
▪Creating a Data View from Templates
