R11.0a-March2023
Enable and Define Follow-up Network Intents
Complete the following steps to enable and define a follow-up NI.
- Open a NI and click Edit to enter the Edit Mode.
- Hover over the CLI Command Diagnosis and click the pencil icon.
- Select the Follow-up Network Intents checkbox to enable it, and then click Add Network Intent.
Define Follow-up Intent from the drop-down list in two ways:
- Select Common Intent: Select one or more NIs from NI Manager to associate.
- Select Child Intent: Select a Child Network Intent from the Intent Family, but the current NI and its parent NI cannot be selected.
Note: When the home NI is used as seed NI of specified NIC, only child Intents can be replicated together, and common Intents cannot be replicated. - Select Intent Cluster: Select one or more NI clusters and set the conditions for matching member NIs.
- NIC Name (for example, 3-Replicate Device and Its Neighbors): Enter the description for this follow-up intent.
- Match Member Network Intents: Set the conditions to match the member NI to be executed next.
- Message for Diagnosis Tree (Post-Execution): Enter some guiding suggestions, like what to do next.
- Define more information for Follow-up Intents
- Define the Description to explain when this NI is executed and when this NI is not executed for the follow-up NI.
- Define the Message for Diagnosis Tree to explain the situation corresponding to the execution of the NI. These messages will be displayed in the link of the Diagnosis Tree.
- Click OK.
