2023-Nov-03-R11.1a
Create Inventory Report
The Inventory report records comprehensive inventory data of your network, including device data, module data, interface data, site data and more.
You can either use built-in reports as templates to export or customize your own reports by specifying device scope and asset data.
User flow
Creating and exporting a customized report consists of the following steps:
  1. Create a new favorite report by filtering the desired objects (devices, interfaces, and the like).
  2. Select a report type (device/interface/module/Qapp report).
  3. Select the required asset data.
  4. Export an inventory report as needed.
UI Components of Inventory Report
The UI components of the Inventory Report are illustrated below:
A screenshot of a computer
  • The folder structure pane: the left pane displays an inventory report folder tree that categorizes all the inventory reports into the respective category of the folder.
  • The information pane:  the right pane displays the asset details of a selected inventory report.
  • The inventory report toolbar: a place where you can carry out inventory report-related operations, such as searching.
The following types of inventory reports are supported in the IE system.
CategoryTypeDescription
Built-in ReportsDevice ReportContains properties of devices in the current domain, such as management IP and device type.
Interface ReportContains the interface properties for all devices in the current domain, such as IPv4/6 address and bandwidth.
Module ReportContains the module properties for all devices in the current domain, such as module ports and slot numbers.
Site ReportContains the summary information for all sites in the current domain, such as location and device count.
Summary ReportContains the summary information for all devices in the current domain, such as module count and interface count.
Customized ReportsShared Reports
Visible and editable to all users in the current domain.
  • FRU Report — contains the chassis hardware information about Cisco routers, Cisco IOS switches, Juniper routers, and Juniper EX switches in the current domain.
  • Stackable Switch Report — contains the stack information about Cisco Routers or IOS Switches in the current domain.
  • VSS Report — contains VSS modules in the current domain.
  • Router_If_Report — contains the interface properties for routers in the current domain.
  • Switch_If_Report — contains the interface properties for switches in the current domain.
  • Other_If_Report — contains the interface properties for other device types in the current domain.
Private ReportsOnly accessible to the report author.
Information TipQapp-based Reports are marked with the  icon.
