Define Playbook
Use either of the following ways to define a playbook
Note: Please follow Ansible’s best practice for the project structure/directory layout (only applicable to Sync Up Playbook from SCM): |
https://docs.ansible.com/ansible/latest/user_guide/sample_setup.html#sample-directory-layout
https://docs.ansible.com/ansible/2.8/user_guide/playbooks_best_practices.html#directory-layout
Use or Install Ansible Role/Collection
One crucial way to organize your playbook content is Ansible’s “roles” organization feature. You can embed your role content in your project directory (Refer to https://docs.ansible.com/ansible/latest/user_guide/playbooks_reuse_roles.html for the best practice of setting up role directory structure) or trigger the installation of the roles/collections on Ansible by including the roles in a requirements.yml file and defining the file in your Ansible project directory.
Note: if you are using older Ansible versions prior to (including) Ansible 2.9, to trigger the installation of collections, please contact NetBrain to apply a small patch. |
Note: The requirements file path must be /roles/requirements.yml in your Git Ansible repo. |
References:
Sample directory layout from Ansible Documentation:
Directory layout from Ansible’s best practice:
Syntax of installing roles and collections from requirements.yml file:
