2023-Nov-03-R11.1a
Create a Widget
Following the steps below to create a widget:
- Click the start menu
and select Network Dashboard Widget & Template.
- On the Widgets tab, point to the category in the left pane and click the
icon to select New Widget from the drop-down menu.
- Fill in the generic information about the Widget, including name (case-insensitive) and description.
- Select the data source for the Widget.
Select Qapp as Data Source
Note: If you select this option, this Widget will be categorized as a monitor widget.
- Select Qapp.
- Click Browse to select a Qapp file and click OK.
The execution frequency of the Qapp is configurable in a dashboard. See Qapp Settings for more details. - Specify the Widget Type, table or chart.
- Select the data type to be displayed in the Widget. If the Event data type is selected, you can skip all the following steps.
- If the widget type is a table, you can select the Display _ Row check box and specify a value to limit the maximum rows displayed in the table. The default value is 20.
- Select a data table from the Qapp file.
Select metrics to be displayed in the Widget.
- In a table widget, the selected widgets are used as column headers.
In a chart widget, the selected widgets are used as the focused parameters in the vertical ordinates.
- If the widget type is a table, select a metric to sort the table. By default, the table is sorted in ascending order, and you can click asc to change the order.
- Select Data Table as Data Source
Note: If you select this option, this Widget will be categorized as a static widget. - Select Data Table.
- Select a data table from the drop-down list.
- Click Save.
Widget Type
Type | Description |
Generic Table | Display metrics in a table. It has the following options:
Generic Chart | Display metrics in a chart. It has the following options:
