Visualize ThousandEyes Instant Test Data with DVT
Use Case
Using publicly available ThousandEyes API, NetBrain has created an integration compatible with NetBrain Integration 8.0 (or newer) that enables NetBrain users to overlay ThousandEyes instant test results data on NetBrain maps.
With this integration, NetBrain first initiates an instant test from a specified ThousandEyes test agent to network devices. When the test results come back, NetBrain overlay the following extended information as attributes.
- Average Latency
- Maximum Latency
- Minimum Latency
- Loss
- Jitter
- Test Agent Id
- Test Agent Name
- Created Date
Note: The instant Test is issued from the selected agent to the NetBrain device management IP. |
NetBrain Map with ThousandEyes Data Overlay
The diagram below shows ThousandEyes instant data overlay on devices.
