Visualize the BMC Remedy Data with DVT
Use Case
NetBrain has created an integration compatible with NetBrain that enables a NetBrain administrator to overlay BMC incident list data on user-created maps.
With this integration, NetBrain can overlay the following extended information as attributes. Device level:
  1. Number of Incidents
  2. Incident Details
Information Note: This solution makes queries to Solarwinds based on the device hostname as the primary key. NetBrain device hostname and Solarwinds hostname must be identical to make this solution functioning.
NetBrain Map with BMC Remedy Data Overlay
Below is an example representation of the BMC data overlay on devices.
