Visualize Physical Networks
With NetBrain, you can quickly search, visualize, and understand devices in physical networks:
  • What you have in your physical network, such as routers, L3 Switches and Firewalls.
User Flow
Prerequisites: Make sure the discovery and benchmark of your physical network have been completed.
The general flow of visualizing physical networks is as follows:
  1. View your physical network tree. NetBrain provides three views to help you better understand your physical network:
  1. Apply Data View Template to Visualize More Data.
