Operations on Intents in Select Intents Dialog
Apart from using Select Intents dialog to select intents across features, you can operate on the intents listed in this dialog. The intents can be filtered by tags in the Select Intents dialog, and tag "All" is selected by default and all intents are displayed.
Common Operations on Intents in Select Intents Dialog
The following operations can also be performed on the intent items:
  • View Intent: Open the intent in View Mode.
Point to an intent item listed in the pane and click the  icon to view the intent in View Mode.
  • Open Diagnosis Tree: View the Diagnosis Tree of the intent item.
Point to an intent item from the intents list in the pane and click the  icon to open the Diagnosis Tree.
Special Operations on Intents in Select Intents Dialog
Three check boxes in the Select Intents dialog can be selected to reduce the loaded intents in this dialog and make it easier to select target intents.
  • Select the Show Intents Serving as Template Only check box: Only the intents that are served as intent template can be displayed.
  • Select the Show Intents for Devices on Current Map Only check box: The intents are filtered by the devices in the current map page.
    Information Note: This check box is visible only when the dialog box is open from a map.
  • Select the Show Published Intents Only check box: Only the published intents are displayed.
