Extend Neighbors
You can draw different types of topology links and neighbor devices on the current map page by extending neighbors, including layer 2 topology, IPv4 layer 3 topology, IPv6 layer 3 topology, and Layer 3 VPN Tunnel.
  1. On your Map, click the icon attached to the target device.
  2. Extend and draw neighbors on the Map.
    1. Select a neighbor type (IPv4 L3 Topology, L2 Topology, Interface, or site) from the drop-down menu to filter neighbors.
Description automatically generateda
      Information Tip: You can enter an IP address or sections of an IP address as the search keyword in the search bar in the left pane to further filter or find interfaces in the left pane.
    2. Select an interface in the left pane. The connected neighbor devices are listed on the right pane.
    3. Select one or multiple neighbor devices, and then click Add to Map. You can also double-click All Neighbors to add all the listed neighbor devices to the Map.
      Information  Tip: You can enter a search keyword in the search bar in the right pane to find the desired neighbor devices or sites from the right pane.
  3. Repeat the above steps to extend neighbors for more devices.
    Information Tip: There are three types of relationships between a site and a device, which are shown in different ways on a map. See Connectivity Between a Device and a Site for more information.
Neighbor Types
The table below lists all neighbor options and the corresponding interfaces that can be selected when you extend neighbors.
Table1 - Selectable Interface for Different Neighbor Device
Neighbor OptionInterface
IPv4 L3 TopologyIncludes all Layer 3 interfaces of the target device or the Layer 3 PE interfaces of the target MPLS cloud configured with IPV4.
IPv6 L3 Topology
(only available for extending neighbors of a device)
Includes all Layer 3 interfaces of the target device configured with IPv6.
L2 Topology
Includes all Layer 2 interfaces of the target device.
L3 VPN Tunnel
(only available for extending neighbors of the device with IPsec/GRE VPN configured)
Includes outside interface of the target device.
InterfaceIncludes all interfaces (including both Layer 3 and Layer 2 interfaces) of the target device or MPLS cloud.
SiteIncludes all device interfaces connected with the site or all PE interfaces of an MPLS cloud connected with the site.
Device
(only available for extending neighbors of a site)
Includes all border interfaces on the border devices of the target site.
When you extend neighbor devices for a site, the connectivity on a map might be one of the following:
Table2 - Neighbor Devices (for Site) Connectivity on Map
Connectivity on MapDescription
Graphical user interface
Description automatically generated with low confidenceThe device is an inner device of this site, indicating that it is not connected to any devices from other sites.
A picture containing table
Description automatically generatedThe device does not belong to the site and is connected to a device (BJ-R1) within the site.
A picture containing graphical user interface
Description automatically generatedThe device is a border device of this site, indicating that it is connected to devices of other sites.
