Create a Personal Map
- Open a map and make the changes per your requirement.
- Click the map name and select Save as My Copy in the drop-down.
- In the Save as My Copy window:
- You can save the Current Page or All Pages as your personal map.
- You can write summary, and the summary will be available on the Map.
- Click OK.
